Hi, I am new to HamWAN. I successfully received S3.Larch/K7WAN http://www.stargazing.net/david/sdr/HSMM.html#P4b <http://www.stargazing.net/david/sdr/HSMM.html#P4b> But, I was not successful doing a traceroute and ping. http://www.stargazing.net/david/sdr/PacificPark20180818.txt <http://www.stargazing.net/david/sdr/PacificPark20180818.txt> How do I apply for a certificate? How do I install the certificate on the portable Mikrotik QRT 5? How do I verify the certificate is installed and is being used by the Mikrotik QRT 5? Thank you for your help. 73 David WA9ONY
You don't need a certificate to ping and traceroute over HamWAN. Let's try to troubleshoot. Can you send the output of /ip export /ip route check 8.8.8.8 Tom KD7LXL On Tue, Aug 21, 2018, 10:07 David Haworth via PSDR <psdr@hamwan.org> wrote:
Hi,
I am new to HamWAN.
I will do the next time I am out. Today I have updated the sw on the QRT 5 and reprogram the settings. 73 David WA9ONY Sent from my iPad
/ip export
On Tue, Aug 21, 2018, 10:07 David Haworth via PSDR <psdr@hamwan.org> wrote: Hi,
I am new to HamWAN.
Hi Tom, I got out and did testing today at a new site. My portable Mikrotik QRT 5 International terminal log is at http://www.stargazing.net/david/sdr/HamWAN20180823Wash.txt <http://www.stargazing.net/david/sdr/HamWAN20180823Wash.txt> with commands /ip export /ip route check 8.8.8.8 I have updated RouterOS to 6.42.6. I redid the HamWAN configuration. My HamWAN Mikrotik QRT 5 client setup is at http://www.stargazing.net/david/sdr/HSMM.html#P4e <http://www.stargazing.net/david/sdr/HSMM.html#P4e> Still traceroute and ping dod not work. Thank you for your help. 73 David WA9ONY
On Aug 21, 2018, at 10:13 PM, David Haworth via PSDR <psdr@hamwan.org> wrote:
73 David WA9ONY
Sent from my iPad
On Aug 21, 2018, at 5:37 PM, Tom Hayward <tom@tomh.us <mailto:tom@tomh.us>> wrote:
/ip export
On Tue, Aug 21, 2018, 10:07 David Haworth via PSDR <psdr@hamwan.org <mailto:psdr@hamwan.org>> wrote: Hi,
I am new to HamWAN.
Looks like the problem is that your modem never got an IP address assigned because it didn't ask for one. On HamWAN that is done with a DHCP client. If you just copy/paste the command from step 22 you should be good to go: https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configura... Tom KD7LXL On Thu, Aug 23, 2018 at 9:26 PM David Haworth <davidahaworth@icloud.com> wrote:
Hi Tom,
73 David WA9ONY
73 David WA9ONY
Sent from my iPad
/ip export
Hi,
I am new to HamWAN.
Hi Tom, Thank you for the help. I will fix the DHCP problem. 73 David WA9ONY Sent from my iPad
On Thu, Aug 23, 2018 at 9:26 PM David Haworth <davidahaworth@icloud.com> wrote: Hi Tom,
73 David WA9ONY
73 David WA9ONY
Sent from my iPad
/ip export
I am new to HamWAN.
Hi Tom, Thank you for your help. I fixed two fo my error in the configuration that affected the DHCP operation. On 8/27/2018 I was successful in operating my QRT 5 portable to set its time by NTP, ping and traceroute. Back to certificates When do I need to use a certificate on HamWAN? How do I apply for a certificate? How do I install a certificate and verify it is correctly operating? Thank you 73 David Haworth http://www.stargazing.net/david/sdr/HamWAN.html <http://www.stargazing.net/david/sdr/HamWAN.html>
On Aug 24, 2018, at 11:26 PM, David Haworth via PSDR <psdr@hamwan.org> wrote:
Hi Tom,
73 David WA9ONY
Sent from my iPad
On Aug 23, 2018, at 10:35 PM, Tom Hayward <tom@tomh.us <mailto:tom@tomh.us>> wrote:
Looks like the problem is that your modem never got an IP address assigned because it didn't ask for one. On HamWAN that is done with a DHCP client. If you just copy/paste the command from step 22 you should be good to go: https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configura... <https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html>
On Thu, Aug 23, 2018 at 9:26 PM David Haworth <davidahaworth@icloud.com <mailto:davidahaworth@icloud.com>> wrote: Hi Tom,
73 David WA9ONY
On Aug 21, 2018, at 10:13 PM, David Haworth via PSDR <psdr@hamwan.org <mailto:psdr@hamwan.org>> wrote:
73 David WA9ONY
Sent from my iPad
/ip export
I am new to HamWAN.
PSDR mailing list PSDR@hamwan.org <mailto:PSDR@hamwan.org> http://mail.hamwan.net/mailman/listinfo/psdr <http://mail.hamwan.net/mailman/listinfo/psdr>
participants (2)
David Haworth -
Tom Hayward
