Objective: When an external (ie, wlan) connection is attempted to port 26 on the radio, forward that traffic ("destination NAT") to a computer on my internal LAN. Firewall rules in the radio (rules #3 & #7 in the filter chain, and rule #1 in the NAT chain, have been inserted by me): //ip firewall filter print Flags: X - disabled, I - invalid, D - dynamic 0 ;;; default configuration chain=input action=accept protocol=icmp src-address=44.0.0.0/8 1 ;;; default configuration chain=input action=accept connection-state=established 2 ;;; default configuration chain=input action=accept connection-state=related 3 chain=input action=accept protocol=tcp in-interface=wlan1-gateway dst-port=26 4 ;;; default configuration chain=input action=drop in-interface=wlan1-gateway 5 ;;; default configuration chain=forward action=accept connection-state=established 6 ;;; default configuration chain=forward action=accept connection-state=related 7 chain=forward action=accept protocol=tcp in-interface=wlan1-gateway dst-port=26 8 ;;; default configuration chain=forward action=drop connection-state=invalid /ip firewall nat print Flags: X - disabled, I - invalid, D - dynamic 0 ;;; default configuration chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=wlan1-gateway 1 chain=dstnat action=dst-nat to-addresses=192.168.0.250 protocol=tcp in-interface=wlan1-gateway dst-port=26/ I use the same technique on my Linux boxes, and it works fine (albeit iptables is slightly different). However, when accessing my radio from an external IP address, no connection is made (times out). If I change the dstnat rule action to "accept", the connection is refused. The logs for port 26 on the target device (192.168.0.250) show no connection attempt. In the (default) srcnat chain, "action=masquerade" implies NATting on the return trip (into the LAN). The same thing needs to happen in a dstnat chain, but I don't see a way to do that; I'm "assuming" that the OS automatically does that. When doing DNAT on Linux, I have to do that manually, with the same rule in the "PREROUTING" and "OUTPUT" NAT chains, but those chains don't exist in my radio. Ideas welcome (note that "action=masquerade" is not valid in a dstnat chain). -- Dean
You can do a bit more debugging here to bridge the gap between "config upload" and "connections don't work". The router has a nice "/tool sniffer quick" utility built-in. Try it with the arguments "interface=all ip-protocol=tcp port=26" and launch a connection in from the outside world. You should be able to see everything going on, from the original packet coming in (or not), to it getting translated and sent to your server (or not), to your server replying (or not), to the un-NAT and retransmission (or not). Somewhere along the line you'll spot the root of the problem. I don't know what it is, as the config looks fine to me. Oh, and screen width DOES matter. I believe if your window isn't wide enough (eg: just 80 columns) it'll omit MAC address details. So, max your window before running the sniffer. Either that or use the winbox GUI sniffer. Please report back! --Bart On 04/03/2014 05:17 PM, Dean Gibson AE7Q wrote:
OK, I tried that (maxing the SSH window gave me 273 columns), and as I suspected, the wlan packets are being forwarded to the target, but the responses are not coming back to the radio. That's the difference between source/destination NAT and masquerading; the latter also modifies the source packet to cause the responses to come back to the NAT box, so that they can be "un-masqueraded" and sent back to the originator. What was happening, is that the responses were being generated, but since the source address (out in the wild Internet) had not been masqueraded, the responses were sent by the default route back to the originator. However, when that happened, the default route masqueraded the response, and so when it arrived at the originator, it had the IP address of the default route (eg, my normal ISP's router), not the IP address of the radio that the originator expected. Result? *DROP.* I needed a second masquerading line, show below in red. Works! On 2014-04-03 18:11, Bart Kus wrote:
Please report back!
/ip firewall nat print Flags: X - disabled, I - invalid, D - dynamic 0 ;;; default configuration chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=wlan1-gateway/// ///1 chain=srcnat action=masquerade to-addresses=192.168.0.250 protocol=tcp out-interface=ether1-local dst-port=26/ // /2 chain=dstnat action=dst-nat to-addresses=192.168.0.250 protocol=tcp in-interface=wlan1-gateway dst-port=26/
Right on! I'm glad you were able to diagnose and solve the problem with minimal assistance! You experienced a version of asymmetrical routing that I recently documented on the LAN Integration page. Another solution for you might be to change the routing table on that server so it uses the HamWAN modem for port 26 comms. The best solution I can think of is to send the packet back out the same interface it came in. With a Linux server you can pull it off there, or you can pull it off on most routers too by enabling connection tracking. That way you don't have to lose the source IP. I documented one scenario of how to do this on the LAN Integration page. It hasn't been tested yet. --Bart On 4/3/2014 7:55 PM, Dean Gibson AE7Q wrote:
Please report back!
Connection tracking was on from the start. The solution is to use masquerading properly, not to rape the routing table. On 2014-04-03 22:40, Bart Kus wrote:
Right on!
Please report back!
participants (2)
Bart Kus -
Dean Gibson AE7Q
